Extra plug after swap??!?
Old Dec 7, 2005 | 02:08 PM
transpar_nt's Avatar
Default Extra plug after swap??!?
I just finished swapping a b18b into my eg this last weekend and I have an extra plug on the engine harness that I can't find a home for. (I used the civic's harness). It's a round female plug with two wires leading to it: black and green. Anyone know what this is?
I think everything is running fine but its hard to tell because the header is open right now and the o2 sensor isn't in fully (going to an exhaust shop to weld up the exhaust for me and weld in a new o2 bung).
Old Dec 7, 2005 | 05:05 PM
DirtRider's Avatar
Default Re: Extra plug after swap??!? (transpar_nt)
where abouts is the plug on your harness?
crank sensor comes to mind.. but i could be way off.
Old Dec 7, 2005 | 06:58 PM
Hercules's Avatar
Default Re: Extra plug after swap??!? (DirtRider)
What model is the civic? maybe a vtec plug? but then you would have two extra's...post a pic and we'll tell you what it is.
Old Dec 8, 2005 | 02:42 AM
Default Re: Extra plug after swap??!? (Hercules)
I don't have a digtital camera to post up pics, sorry.
The harness is from a '92 civic lx, so no vtec. It is near the starter and thermostat on the b18, but was most likely right in the middle on the d15 because the harness is stretched a little now.
Old Dec 8, 2005 | 06:19 PM
to the top
Old Dec 9, 2005 | 12:46 PM
up
Old Dec 9, 2005 | 08:49 PM
bumpzzors.
Old Dec 10, 2005 | 08:51 PM
Slopoke's Avatar
The two wire coolant temp sensor on the head(kinda under the distributor)?
Fan switch, on the thermostat housing?
Old Dec 11, 2005 | 01:05 AM
Default Re: Extra plug after swap??!? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">The two wire coolant temp sensor on the head(kinda under the distributor)?
Fan switch, on the thermostat housing?</TD></TR></TABLE>
I'm thinking it may be the fan switch. I've read that the b18a has the plug on the back of the block, and the b18b has it on the thermo housing. The problem is that I have a 97 b18b that was previously installed in a '90 LS, so most of the misc parts surrounding the actual engine are from the DA (including the t-stat). This would explain the reason I can't find a place for the plug. The car is currently at a muffler shop for some welding and I've only driven it the 10 minutes it took to get there so I have no idea if the fan is working or not...
Old Dec 11, 2005 | 07:33 AM
Slopoke's Avatar
You can fix that easy enough. Just grab a thermo housing for a '94+ LS.
Old Dec 11, 2005 | 11:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">You can fix that easy enough. Just grab a thermo housing for a '94+ LS. </TD></TR></TABLE>
I'll make sure that this is indeed the plug for the fan switch first. If so, then I guess I'll find a newer thermo housing at a junkyard or something. Thanks man!
Alex V
Jul 5, 2019 10:46 AM
rsw912
Jul 11, 2012 03:06 PM
mxracer420
15
Apr 25, 2009 10:42 PM
unclemeat8
Nov 13, 2008 05:21 PM
headhunter
15
May 31, 2006 03:38 PM
