Rear bracket doesnt fit on B16 in EG, HELP!!!!!!!
Ok well i bought my 94 HB with the b16 swap into it and when i noticed the motor mounts were goin out i replaced them. But I found that the rear motor mount, the one that goes on the cross member for the rack and pinion, wasnt ever connected. I went ahead and replaced the mount but just to get that out of the way. Now the reason it isnt connected is because the bracket coming off the motor is about an inch or so too short. Just curious if i have the worng bracket and if so does anyone have one for sale? I will try to load up a pic of my bracket. <img http://atkipage.50megs.com/ima...0.jpg>
Re: Rear bracket doesnt fit on B16 in EG, HELP!!!!!!! (corollagts33)
It is probably the stock bracket, not a correct bracket. You picture didn't work.
Is there a hole in the T part of the bracket when looking at the side view?
We do offer the correct back.
ok well i found the corrects bracket. I had to get the 95 GSR t bracket. I guess i had the stock b16 bracket and it just want long enough. Problem is fixed now and thanks for the info.
jDmImagE
10-15-2005 01:18 PM
coot_er
22
05-02-2004 09:07 PM
rice_classic
11
03-10-2002 12:01 AM
