H22 PROBLEM
OK GUYS I DID SEARCH BUT DIFFERENT AXLES.... ok i have a h22 in a 99 civic coupe..i research and lot of people say to use 90-93 integra axles..i when to buy a 91 accord innershaft and found out it was the same as the 93 prelude innershaft(unless they sold me the wrong one) will anyways when i was going to buy the 90-93 integra axles i notices that the driverside are both male so i did get it...instead i used 95 integra axle w/o abs (the shop said the 90-93 axle p-side is the same as the 95 integra p-side axles and he showed me the code)....the driver side work great but my passenger side don't seem right..when i floor it it seem like the axle isn't grabing anything it seem like it is just spinning...is that binding..?? or what is binding?. when i turn left or right everything is fine...but when i floor the gas pedal..it seems like the teeth on the axle isn't grabing witht the tranny teeth and it is just spinning...any advise should i get the accord or prelude joint and put it on the 95 integra axleshaft?? i searched for the longest time and still dont' get it..
i`m not positive but i dont the the car would even move if the shaft wasnt turning the wheels....i believe both shafts have to be turning both wheels in order for the vehicle to move...b/c if u break a shaft (just one) the car wont move
yea you have a point there..then what is the problem? it felts like when a car can't grab traction, that is what it feels like and sound like but i know that the tires and traction isn't the problem..
Although Iv'e never dealt w/ the accord shaft. Everything I've read over the past two years says that you need different axles for the prelude intermediate as opposed to the accord intermediate. Therefore, they must be different. You might have a prelude intermediate shaft on your hands.
so what can it be? can it be the axles? should i take my 95 integra axles out and put in the 90-93 integra axles? pside...i don't know if that will help cause the shop said it was the same length..are 95 and 93 integra axle the same? i need help asap, i can't floor my car cause it fell like the wheel is going to pop out with i smash.
the prelude intermediate shaft is a male. (im positive on this)
the accord's is a female. (- i think... lol...)
as for the pass side. whichever integra axle u use.. u should put a prelude inner joint on there to match the tranny.. a prelude joint goes in the prelude tranny.
also what mounts are you using?
Modified by hondaZvic at 2:15 PM 12/10/2005
this is the setup i`m using! 90-93 teggy axle on the driver side with a prelude inner joint! and on the pass side a 88-89 teggy axle and it works PERFECT!!!
this is in combonation with a 93 prelude intermidate shaft
iv4hcx3l4
32
Feb 10, 2008 07:06 PM
