Need to get 99 LS BARD, HELP!!
putting in a 99 LS in my 95 coupe, wanting it to get it BARd, i think i have all the ****, not really sure hope u guys can help me, i know its OBD2 but i'm putting it back to OBD1, so far i have OBD1 ECU, OBD1 intake manifold, and OBD1 Dizzy, and even the 95 OBD1 Wiring Harness please help me and let me know everything else i need, i'm trying to do this right, need your help, thanks
Re: Need to get 99 LS BARD, HELP!! (SPNFEDEJ)
don't tell the ref it is a obd2 motor. he will fail you. play it off like it is a 95 motor. if he says something about the year of the head, just tell them the engine supplier assured you it was a 1995. all you have to do is make sure your vacuum lines are routed right, all of your smog equiptment is present and if you have anything aftermarket attached to the motor, then make sure you have the appropriate CARB sticker for it.
A.E Motoring
32
12-12-2005 12:44 AM
