h22a ej and vibration problem.
Old Dec 7, 2005 | 12:17 PM
GeeGee's Avatar
Default h22a ej and vibration problem.
Car: 93 ej, stock height, stock suspension
Engine: Usdm H22a4
I searched:
8 topics in recent content
16 topics in achieved content
....and I read through all the relevant ones without any result.
My vibration problem is rather simple. It not caused by axles binding since it vibrate just as bad when I gave it gas in neutral or let off the gas while the car still moving. The vibration is not as bad at idle, but as soon as I give it a little gas, the whole car rattle loudly, it seems like the vibration is there through all range of rpm.
I bought these mounts from ebay as a compulsive buy and that was totally dumb of me.
I’m leaning toward the quality of the mount as the cause of the vibration. But before I spend more money replacing the mounts, I want to rule out all the other facts.
1. I’m running stock, which is 97+, rear bracket, even though it fit but it took some creativity do so….would a 92-96 rear bracket solve this problem?
2. Would the absent of balancing shaft cause this problem? I haven’t check since I haven’t got a lightest idea where it would be.
3. If you can think of anything else please feel free to chime in.
Old Dec 7, 2005 | 01:36 PM
IHateJDM's Avatar
Default Re: h22a ej and vibration problem. (Lycanthrope)
I doubt your mounts are causing it since the better aftermarket mounts that use polyurethane bushings transfer most of the motor vibration to the chassis too. If you don't have your balance shafts, or the belt is cut, that could be it. The balance shafts are in the bottom of the motor on either side of the crank (look at the driver's side of the motor by the crank pully).
Old Dec 7, 2005 | 01:47 PM
GeeGee's Avatar
thanks, i'll check it you to day. If anybody need a vid to see the vibration, that could be arranged as well.
Old Dec 7, 2005 | 05:12 PM
GeeGee's Avatar
Default Re: (Lycanthrope)
would the rear bracket cause this problem?
Old Dec 7, 2005 | 06:18 PM
BiGbLoCkHoNdA05's Avatar
i removed my balance shafts and i dont have this problem. and i`m using the same mounts as u...but i am using a 93 rear bracket..doubt that is ur problem
Old Dec 7, 2005 | 10:02 PM
lodo1's Avatar
make sure your mounts are all tightened up? especially the rear one on the crossmember
Old Dec 7, 2005 | 10:25 PM
GeeGee's Avatar
Default Re: (BiGbLoCkHoNdA05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGbLoCkHoNdA05 &raquo;</TD></TR><TR><TD CLASS="quote">i removed my balance shafts and i dont have this problem. and i`m using the same mounts as u...but i am using a 93 rear bracket..doubt that is ur problem</TD></TR></TABLE>
so basically we have the same set up except for the rear bracket, I"ll look into that since that's seem to be the only factor.
karen1961
Jun 18, 2017 04:59 PM
carnot
Jul 11, 2013 07:05 AM
wk9k
26
Apr 25, 2012 03:10 PM
rhdcivic05
Mar 8, 2009 08:18 PM
REDBARON
Jul 18, 2002 08:52 AM
