Axles are too long??
Hello - I own a 95 Acura Integra GSR with an H23 swapped into it. Ever since I put the engine in I have had an issue that when i go over bumps quickly or have a lot of weight in my car or turned a corner too quickly my car would shake and grind. It sounds almost like my tires are hitting the chassis - So! I figured my shocks were bad, and they were, so i purchased a new set of Tokicio Illuminas. They work great but the problem still remains. So I took my car to a shop and they looked at the suspension components and everything checked out fine. Except they said my Half Shafts were too long. Alright - now we get down to my question -
On a hybrid - am i going to have problems with the axles anyways so should i just buy an entire new set of axles to circumvent any issues down the road? If i should do that what should i look at buying? I am planning on having the h23 vtec in my car so right around 190 whp and wtq so nothing huge. What should i expect to pay for such axles?? anyone have any recommendations??
secondly - Is this going to hurt my car if i leave it like it is, should i quit driving it asap or just continue
Third - Should I just replace the halfshafts and call it a day??
Fourth - any other input you guys may have on the situation - as in do you think its something else i could check out or have you heard of an easy fix..??
Thanks much!
Thanks much!
Re: Axles are too long?? (2point2)
http://hasport.com/catalog/pro...id=29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
EGH2AX)Complete axles for the 92-00 Civic, 94-01 Integra & 93-97 Del Sol with an F or H-series swap... $399.00
(EGH2AX)Complete axles for the 92-00 Civic, 94-01 Integra & 93-97 Del Sol with an F or H-series swap...
Click to enlarge
EG H-series axles........ etc.
The EGH2AX axles will only work with the EGH2 mount kit. If you have the older EGH1 mount kit these axles will not work. Call us for the correct axles.
Hasport Axles are made from completely brand new parts and do not require a core like many other competitors do.
Hasport stocks axles for all the swap options offered by Hasport.
These axles are rated to handle up to 200 horsepower at the wheels.
Hasport also offers axles for higher horsepower applications please call for more information on these special order axles.
Also, skunked can probably help you out.. he has an H22 in a DC.. it runs mid 14's I believe..
Click to enlarge
nObOdy65
02-09-2006 10:20 PM
