HCP H22 Users, Anybody making 400+ with them?
Like it says. I am wondering if anyone has made big power on em. Obviously moding the inserts so they are solid. But the mounts themselves, will they hold up?
R.I.P.
Re: HCP H22 Users, Anybody making 400+ with them? (SlowAzEg)
i was under the impression the mounts were solid to begin with... not much room for the h22 to move around in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowAzEg »</TD></TR><TR><TD CLASS="quote"> Like it says. I am wondering if anyone has made big power on em. Obviously moding the inserts so they are solid. But the mounts themselves, will they hold up?</TD></TR></TABLE>
I'd pick up a couple extra inserts and do the trimming on the hang over part and stick them in the middle. They will be a ton more solid. After that, they are steel, so as long as you don't drop it off a cliff or something, you should be just fine.
When I had HCP mounts I broke the rear mount...not ths insert, but the actual metal tore, so it was only bolted down with 2 bolts rather than all 3. HCP warranteed it without an issue, but it was kind of odd to see that happen with stock power levels.
Re: HCP H22 Users, Anybody making 400+ with them? (520Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 520Motorsports »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
520, did u switch from HAsport mounts to HCP or something??
