crx wired with obd2b and aem 1010
ok heres what i have got. I have wired in all the wires for obd2b in my crx and have went over and over them again to make sure they are "where" they are supposed to be. i have a b18. heres the ?s. I have a 1010 for 99 si i have a obd0 and obd2 distributer and before i forget i have re wired my obd0 plugs back in so i could check if it runs still and i didnt fry anything. so here we go, I hooked it up and turned it on connected loaded integra base cal. it would turn over and fuel pump works i can hear it,it will stat sync but not read any rpm, it will also cough once at first but then nothing. i checked the wires again and they all seem to be hooked up properly. i also switched ckp and cyp and it wouldnt cough.
then i changed spark teeth to 1 and then it reads rpm. but doesnt fire anymore. and the dist is getting hotter than it should. so im stumped for now, but ihave been thinking. I dont have a 4 wire o2 hooked up all i have is lambda input does that make a diff on startup? and for the injectors i have stock 240s with a resistor box. i have went in a changed them to the proper ohms and i have rc 440s that i can put in when it runs.
i have changed the sensor for cam to pre92 dis and others to see if it will run with that dist that i have put inbut nothing. I fried my stock obd0 dist some how cause it was to hot i figure
So i guess that i need to do somthing im not and i cant think of anything else to get it to run. maybe a little insite.
Or maybe i can get a output list of which outputs are to what pins i think that would be great.
nevermind i figured it out
Modified by 98lude-t at 9:39 AM 12/17/2005
cherroneballs
06-01-2010 07:30 AM
98lude-t
01-12-2006 07:48 PM
