Need help with del sol asap
I'm about to get a del-sol and I want to swap my b18a turbo setup into it. I know i need the hasport tranny mount and clutch adaptor. But what linkage and and mounts would I need to use for the back and the drivers side, and will me b18a axles thats i was using in my crx work?????
Re: Need help with del sol asap (BoostedEgHatchFl)
I'm am almost positive all b-serise axels are all the same. (correct me if im wrong someone). You will need a del sol VTEC shift lickage. I think you will need mounts from a 94 gsr or del sol VTEC
Re: Need help with del sol asap (eg2sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2sol »</TD></TR><TR><TD CLASS="quote">I'm am almost positive all b-serise axels are all the same. (correct me if im wrong someone). You will need a del sol VTEC shift lickage. I think you will need mounts from a 94 gsr or del sol VTEC </TD></TR></TABLE>
Axles should work w/ matching intermediate shaft.
Re: Need help with del sol asap (Hercules)
Bump so I can use the axles than I'm using in my crx right now in the delsol. Anyone else for sure on the linkage and the mounts.
you can use the axles if they a b-series and have matching drivers side axle/intermediate shaft. 89-93 b series intermediate shafts are different then 94-up
so they work if they match. linkage you will have to use 99-00si or del sol dohc shift linkage.
roque-pr
19
03-24-2010 05:21 PM
