B18 Install in EF (bay area??)
Anyone know who can do a '91 b18a1 install (obd0) in a 91 EF hatchback?
I Have everything needed for the swap except for the hubs, and axles (still looking for those) I could put the engine in and everything, but I have no idea on what to do for the wiring. If someone local could help out, or even do the whole swap it would be cool. I got cash.
Let me know
Modified by deanh8 at 10:12 PM 12/8/2005
Modified by deanh8 at 10:33 AM 12/28/2005
Let me know
Re: B18 Install in EF (deanh8)
all you need is ecu, motor trans axles mounts and shift linkage distributerand your old engine harness as long as its a mpfi harness if not you will have to convert it to mpfi from dual point.
Re: B18 Install in EF (SiKnezzALLmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKnezzALLmotor »</TD></TR><TR><TD CLASS="quote">redzone can install your motor hit em up ask brandon or jeremy </TD></TR></TABLE>
Yeah but for how much? I heard redzone was hella expensive
Re: B18 Install in EF (98lude-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98lude-t »</TD></TR><TR><TD CLASS="quote">all you need is ecu, motor trans axles mounts and shift linkage distributerand your old engine harness as long as its a mpfi harness if not you will have to convert it to mpfi from dual point. </TD></TR></TABLE>
Yeah its DPFI
I have the tranny now, mounts, integra shiftlinkage, I do need the hubs, ecu, and axles though.
Yeah its DPFI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deanh8 »</TD></TR><TR><TD CLASS="quote">Yeah but for how much? I heard redzone was hella expensive</TD></TR></TABLE>
why dont you call them and ask? How much do you think something like this should cost? I'm sure you can find someone on here that will do it in thier driveway for a 12 pack of beer and $100, but what happens if something goes wrong when you drive away? Are they going to be willing to help you out after you leave. Are they going to make sure your car has no check engine lights and all the smog devices are connected so you can take the car to the Ref and pass inspection? The saying goes like this " You get what you pay for. " Redzone as some of the best customer service I have ever seen from a shop in NorCal. In my opinoin redzone is worth the money. I have seen them go way out of thier way to make a customer satisfied.
Re: B18 Install in EF (NorCalAllMtr408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorCalAllMtr408 »</TD></TR><TR><TD CLASS="quote">
Im kinda on a buget and the $1,800 quote from redzone awhile back was way our of the question.
I can put the engine in the car, and connect the mounts. Its really just the wiring I dont have time for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deanh8 »</TD></TR><TR><TD CLASS="quote">Im kinda on a buget and the $1,800 quote from redzone awhile back was way our of the question.
I can put the engine in the car, and connect the mounts. Its really just the wiring I don't have time for.</TD></TR></TABLE>
If I quoted you $1,800.00 then it was more then just a swap. This swap from us if you have all the parts is $750.00 car comes in running and leaves running. If you need just the wiring done then its $350.00 for the wiring and to start it up and make sure everything is in order. No check engine lights and so on. I'm not sure where you got $1800.00 from but I hope I don't have to hurt someone at the shop for quoting you wrong Are you sure you didn't ask for more then just the swap done? Maybe a new clutch, Timing belt, Water pump, and so one? no matter. If you need just the wiring done let me know. I would be happy to help you out if you need it.
Modified by RedZone at 11:29 AM 12/29/2005
Re: B18 Install in EF (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">
Modified by RedZone at 11:29 AM 12/29/2005</TD></TR></TABLE>
That sounds more like it
I dont remember who I talked to but it was a few months ago when I was just thinking about doing the swap. I will keep you guys in mind after I get all the parts. Still having trouble finding hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">I can get the hubs....let me knwo if you need them still and i will get a price for them</TD></TR></TABLE>
Yeah I need them. I also need a PR4 ECU becuase the one I was going to get was messed up.
Re: B18 Install in EF (Heron of Alexandria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heron of Alexandria »</TD></TR><TR><TD CLASS="quote">hubs???? do you have a civic std?</TD></TR></TABLE>
Yeah , 1991 Civic Hatchback STD with DPFI
Yeah , 1991 Civic Hatchback STD with DPFI </TD></TR></TABLE>....thats a good thing std are lighter than the other HB, aren't they??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heron of Alexandria »</TD></TR><TR><TD CLASS="quote">....thats a good thing std are lighter than the other HB, aren't they??</TD></TR></TABLE>
Its a 91, its heavier because of the seat belts are in the doors, and they have more reinforcements in the doors. When I got it smogged, the paper said 2,695. I don't know if that was with the guy in it, or what. But I don't see how it can weigh something with only the front 2 tires on the things.
Ef9_408
12-30-2017 04:01 PM
Dan GSR
12
09-07-2003 09:16 PM
