OBD1 b18b integra motor into 92-95 civic eg
Im considering an obd1 integra motor to swap into my eg, do i need to run any kind of extra wires? or is it just straight up plug n play since its obd1. are there any kind of sensors that need to be wired up to the ecu?. is there anything specific that i need to know about the wiring?.
thanks in advance.
thanks in advance.
Re: (BoogiepopJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoogiepopJDM »</TD></TR><TR><TD CLASS="quote">its actually a cx i know about the 2 wire to 4 wire 02 harness change</TD></TR></TABLE>
no you dont! its ONE wire to FOUR wire. Other than that its simple. Extend a couple of plugs on the civic harness and thats it
Re: (BoogiepopJDM)
You can use either, but if you use the integra engine harness, you wont have to do ANY wiring(since the o2 wiring is part of the engine harness).
Simply plug everything in and you're done.
spl_civic
14
05-05-2003 12:16 PM
