low cylinder compression
Old Dec 7, 2005 | 10:24 AM
B-SerioUs EGg's Avatar
B A N N E D
Default low cylinder compression
i have a b18b1 that has about 120K on the clock. i had tech do a compression on it, and the compression was found to be:
120's-130'-120's-120's
im not able to do a leakdown test on it because, 1 i dont have the tool, and 2 the motor is outside of the car and it cant be brought to a shop that has the leakdown tool.
i plan on changing out the piston rings. should i go ahead and change the headgasket too?
is there anything else that the engine is schedule for a change for?
Old Dec 8, 2005 | 04:53 PM
B A N N E D
Default Re: low cylinder compression (Frosty R81)
Old Dec 8, 2005 | 05:40 PM
lsvtecracer's Avatar
Once you take the head off the block, i would definitely recommend changing out the headgasket. Check the bearings and change them too if needed. Beside that, I would change out the waterpump, timing belts, and all seals since you got it apart.
CNSK
Apr 10, 2005 08:54 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
greenli0n25
Jan 26, 2004 07:29 AM
98civicEX
Apr 8, 2003 10:55 AM
bleebdat
Oct 8, 2002 03:52 AM
