gsr swap into ek
gsr swap into ek
ok i have a 98 ex coupe and i just bought a obd1 gsr swap from hmotorsonline what else do i need besides a 0bd2<obd1 adabter. Like what mounts and i want to keep my ac.
Re: gsr swap into ek (eg6b18boy)
look on http://www.hasport.com
i believe stock mounts work, you just need a rear tranny mount from a 99-00 si and a del sol ac bracket i believe. but yea double check with hasport, it's on their website.
Re: gsr swap into ek (knockout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout »</TD></TR><TR><TD CLASS="quote">look on http://www.hasport.com
i believe stock mounts work, you just need a rear tranny mount from a 99-00 si and a del sol ac bracket i believe. but yea double check with hasport, it's on their website.</TD></TR></TABLE>
Correct. Also a shiftlinkage and axles if didn't come with the swap.
HASport does still offer an upgrade kit, though the stock mounts will work (which we offer).
Re: gsr swap into ek (jdmcars.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">
HASport does still offer an upgrade kit, though the stock mounts will work (which we offer).</TD></TR></TABLE>
You need the timing belt side bracket for the '99-'00 si. (its the bracket that sits between the mount that bolts to the block and the rubber fluid filled mount).
Then reuse your stock civic upper tranny mount.
ANGELIQUE
03-15-2005 12:25 PM
