LSVTEC: Timing Belt Covers
I have a LSVTEC hatch and with a gsr head. My car didn't come with the timing belt covers. Would I just go on getting a LS bottom cover with a gsr or b16 top cover? For those who did it, did it match up fine?
Re: LSVTEC: Timing Belt Covers (foam)
When I installed my timing belt covers all three pieces were from a 99 GSR motor (even the lower cover) There was however cutting involved on the back cover to get it to line up flush and not rub against the timing belt. It took some time, but it wasn't too hard to do. Just take a good look at what is in the way and trim the cover accordingly. Good luck.
Re: LSVTEC: Timing Belt Covers (EGgsrAM)
I'm using the ls bottom covers and the b16 top covers with a b16 head. With my set up I had to do a bit of cutting aswell but it was easy to make it fit.
Re: LSVTEC: Timing Belt Covers (Rukusmasta2)
yeah a lot do to adjust cam timing. or just show off there bling bling cam gears. glad you dident take my comment the wrong way
Todallybuilt
01-26-2018 05:07 AM
92integraVTECgsr
05-25-2008 07:04 AM
