First Pass with H22
First Pass with H22
street tires :
14.4
mph-98.8
60ft-2.4
mods:
usdm motor with TypeS pistons and cams
stock ecu
stock header and civic exhaust
checked my plugs and they are a whitish tent...so i`m guessing i`m running lean.
car pulls hard low end and suffers on topend. but its not really smooth in lowend power
any sugestions on what to do.
14.4
mph-98.8
60ft-2.4
mods:
stock ecu
Unceasing Measure
Re: First Pass with H22 (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">Tune then track, not track then tune!</TD></TR></TABLE>
True
True
stock p13 ecu. i was wondering about that JDMSHIT chip, but then i did some research and it dont seem to help. also i have 2 CELs egr. and o2 codes are present
Re: (GoTaWd92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoTaWd92 »</TD></TR><TR><TD CLASS="quote">stock p13 ecu. i was wondering about that JDMSHIT chip, but then i did some research and it dont seem to help. also i have 2 CELs egr. and o2 codes are present</TD></TR></TABLE>
so your running rich........... fix your CEL's.
i installed some colder plugs today and it seems to be running better. but i`m tryn to get this lean problem fixed so i can use the N/X kit that i installed 2 weeks ago
Re: (BiGbLoCkHoNdA05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGbLoCkHoNdA05 »</TD></TR><TR><TD CLASS="quote">i was wondering about that JDMSHIT chip, but then i did some research and it dont seem to help. </TD></TR></TABLE>
yeah, i've got one of their chips at home now. I used to run it, but now I just run a stock p13 rom in a p28. My 1/4 times are almost identical with the 2 chips, but the stock rom feels more fluid, especially at lower rpms. Drop those 60's and you'll hit 13's.
Re: (IHateJDM)
When I was all motor I had a p28 with that jdm **** program, it ran really good. I never got a better 60' on street tires than 2.2, never got lower than 14.2. I went back out on slicks and put down a 1.7' with a 13.5. And that was in a full interior SI hatch at 3750ft above sea level. Withy the H22's you NEED sticky tires, your car is fast, get a good tune and some sticky tires...
Re: (BigBlock)
I'm running the p28 with the h22 jdmshit chip too. Best run was 13.2 at 102 running 22x8x13 slicks on bogarts pulling 1.7 60.
I've heard that the jdmshit chips run a h22 type-s map, so it makes it run rich. Anybody can confirm this?
Re: (xv53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xv53 »</TD></TR><TR><TD CLASS="quote">I've heard that the jdmshit chips run a h22 type-s map, so it makes it run rich. Anybody can confirm this?</TD></TR></TABLE>
i've heard the same, and after i switched to a p13 rom, my friends tell me there is less black smoke from my exhaust at wot. I don't have any a/f figures to back it up, but i'm getting better gas mileage now too.
BTW, my best 1/4 time with jdmshit chip was 13.89 @ 99.12 (2.168 60'), and with the p13 rom its 13.91 @ 99.05 (2.169 60'). Pretty damn close.
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
BTW, my best 1/4 time with jdmshit chip was 13.89 @ 99.12 (2.168 60'), and with the p13 rom its 13.91 @ 99.05 (2.169 60'). Pretty damn close. </TD></TR></TABLE>
p13 rom in a p28? where did you get that one from? I'd like to try it out too...
Re: (xv53)
a buddy of mine has a chip burner. I actually have the jdmshit rom saved on my computer at home if you want to see exactly what the fuel maps look like.
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">a buddy of mine has a chip burner. I actually have the jdmshit rom saved on my computer at home if you want to see exactly what the fuel maps look like. </TD></TR></TABLE>
send it over to my email: linavs@verizon.net.
Re: (xv53)
I ran mine with a adj fuel pressure regulator, mine didnt run rich. Runs a little rich now though, oh wait thats because of the 880 injectors
Re: (BigBlock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlock »</TD></TR><TR><TD CLASS="quote">I ran mine with a adj fuel pressure regulator, mine didnt run rich. Runs a little rich now though, oh wait thats because of the 880 injectors </TD></TR></TABLE>
what did you do, remove some fuel pressure?
Re: First Pass with H22 (BiGbLoCkHoNdA05)
i had the same experience with my car, recheck your ign. timing. after i did that i went from a 14.3@98 to a 13.7@101 first run just. my suggestion and experience
i want to run slicks but i`m scared of breaking axles. and what is the timing that ur motor is set at? that way i can get an idea of what to set mine at
