gas problem help please
Old Dec 3, 2004 | 05:33 AM
barry11j's Avatar
Default gas problem help please
whats up people....i am having a terrible gas problem ( car ) that is..........i am getting like 10 mpg !! i have a 91 crx si with a b16A swap....i have a new timing belt, head gasket, dist, and water pump...well i dont know why i keep smelling STRONG fumes in the cabin and outside the car....if i was to drive around for 30 mins then i would smell like straight GAS !!!!....i also have 2.25 pipes from the man back...no CAT.......i looked at the fuel rail and lines...i cannot find a leak !!! is there anything else i can look 4...i need help bad..i am running shell V-power fuel
Old Dec 3, 2004 | 06:32 AM
v4lu3s's Avatar
RTFM
what ecu are you runninbg and are you getting check engine lights at all?
Old Dec 3, 2004 | 08:20 AM
VTECVillain's Avatar
Default Re: gas problem help please (barry11j)
If you are smelling raw fuel then it's either leaking somewhere or you are running crazy rich thus possibly dumping fuel into your cylinders. (not good!) Definitely check all of your fuel lines, injector seals and o-rings. Check your plugs for signs of overly rich and also check the oil and see if it has a fuel smell to it. Jump the test harness and check to see if the ECU has any codes stored.
Old Dec 6, 2004 | 10:43 AM
barry11j's Avatar
Default Re: gas problem help please (VTECVillain)
i checked for leaks...found none...i am throwing code 5....i think i am getting gas in my OIL.....what is going wrong here??!!!!
Old Dec 6, 2004 | 11:47 AM
barry11j's Avatar
can the map sensor be dumping all the fuel in?
Old Dec 6, 2004 | 12:14 PM
barry11j's Avatar
i am smelling gas in the OIL as well
Old Dec 7, 2004 | 10:07 AM
barry11j's Avatar
can anyone help???
Old Dec 7, 2004 | 05:41 PM
v4lu3s's Avatar
RTFM
if you are getting a code 5 i would fix the source of that problem.
Old Dec 8, 2004 | 05:38 AM
barry11j's Avatar
Default Re: (v4lu3s)
i checked all of the hoses to my map sensor and i cant find any leaks...how can you tell if the sensor is bad?
egsickz0
Feb 10, 2011 07:52 AM
scottmog
16
Jan 1, 2009 11:49 AM
bitz95civ
Dec 30, 2005 02:38 PM
jdmJP
Aug 20, 2004 11:53 AM
Steve90HB
Apr 4, 2004 11:08 AM
