How do you take of a h22 crank pulley?
i bought an unorthadox crank pulley and i was wondering if some one can explain how to take off my stock h22 crank pulley? thanx
Re: How do you take of a h22 crank pulley? (EGhatch22)
Depends on your impact wrench, but it might not be strong enough. I know mine's not.
If you don't already have a Honda crank pulley holder tool, get one. Then use two breaker bars, one to hold the pulley and the other to break the bolt. Just use a bigass cheater bar
Well this is how I did mine. i use a big flat head screwdriver and stuck between the flywheel and tranny housing to stop the crankpulley from moving. Just take out the black tranny cover. Then use a long *** cheater bar, 5 foot to be exact. That should get it loose. If not then you need to lift some weight jp bro
