1993 CX and OBD1(1995) GSR - O2 sensor question
Tried searching. Couldn't exactly find what I needed. What O2 sensor will I need to use for this swap? Not sure if anyone has experience with this exact swap or not but I'd like to hear the solutions. I wasn't sure if I can use the CX sensor or not.
Thanks,
Shaun
Thanks,
Shaun
Re: 1993 CX and OBD1(1995) GSR - O2 sensor question (HondaBullSQ)
Re: 1993 CX and OBD1(1995) GSR - O2 sensor question (neeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neeks »</TD></TR><TR><TD CLASS="quote">look on the second or third post..
https://honda-tech.com/zerothread?id=1078737</TD></TR></TABLE>
Good advice. I have a 94 cx and i just made my own vtec/4-wire O2 harness for the b16 swap.
Good luck with your swap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaBullSQ »</TD></TR><TR><TD CLASS="quote">So either find a B-series O2 sensor or I'll assume EX (D-series) O2 sensor? </TD></TR></TABLE>
Basically you can use any Honda/Acura or aftermarket replacement 4 wire O2 sensor.
.adam.
07-09-2006 12:40 PM
