99-00 Si harness, how can you tell?
Old 12-08-2004, 07:10 AM
Biloxi's Avatar
Default 99-00 Si harness, how can you tell?
Hi All,
How can you tell if the harness is from 99-00 Si? I brought one from a guy on HT but he did not keep his words on the ECU which he would included as well.
Thanks!
Old 12-08-2004, 03:14 PM
pb16b's Avatar
Default Re: 99-00 Si harness, how can you tell? (Lordkoo)
which harness? engine harness? if so, you can tell because there will only be one 02 sensor plug. the other is on the chassis harness.
Old 12-08-2004, 04:50 PM
Biloxi's Avatar
Default Re: 99-00 Si harness, how can you tell? (pb16b)
It is the engine harness from SI. I am wondering how it will actually look like. Please give me a few pointers here.
Thanks!
Old 12-09-2004, 02:50 AM
JoeB18R's Avatar
Ill take some pics of mine this weekend when I put my P28 Uberdata in. I had to get a new harness for it so my stock one is a comin' out.
Old 12-09-2004, 12:42 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordkoo &raquo;</TD></TR><TR><TD CLASS="quote">Hi All,
Thanks!
is there a white tag on this supposed Si harness with a part number listed on it? if so, whats that part number?
Old 12-10-2004, 08:45 PM
Biloxi's Avatar
Default Re: 99-00 Si harness, how can you tell? (JoeB18R)
Please let me know. Thank you so much!
Old 12-10-2004, 08:46 PM
Biloxi's Avatar
Default Re: 99-00 Si harness, how can you tell? (K@man)
The white tag's part # has been erased. I can't read nothing out of it
Old 12-13-2004, 07:26 AM
Biloxi's Avatar
Any update on this?
Thanks!
Old 12-22-2004, 07:52 AM
Biloxi's Avatar
Joe18R, did you manage to get the Si harness out?
Thanks!
Old 12-22-2004, 09:41 AM
Trey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">which harness? engine harness? if so, you can tell because there will only be one 02 sensor plug. the other is on the chassis harness.
The 96-96 EX harness also only has one 02 plug on the engine harness.
If you have a 99-00 Si harness then you will not have a 16-pin plug at the ecu.
The 96-98 (OBDIIa) use a 32 pin, a 31 pin and a 16 pin plug at the ecu.
reference pic per Kat
The 99-00 (OBDIIb) use a 32 pin, a 25 pin and a 31 pin plug at the ecu.
Old 12-22-2004, 12:27 PM
pb16b's Avatar
Default Re: 99-00 Si harness, how can you tell? (Trey)
are you sure? the engine harness on the '96 does have 2 o2 sensor plugs because the cat is out front with 2 o2 sensors. i did the swap on my car just a couple weeks ago and it did have 2 plugs, primary and secondary.
Old 12-23-2004, 09:54 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? the engine harness on the '96 does have 2 o2 sensor plugs because the cat is out front with 2 o2 sensors. i did the swap on my car just a couple weeks ago and it did have 2 plugs, primary and secondary.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">The 96-96 EX harness also only has one 02 plug on the engine harness.</TD></TR></TABLE>
I think you're talking about the Cx/Dx harness - Trey is strictly talking about the Ex harness.
Old 12-23-2004, 12:42 PM
pb16b's Avatar
Default Re: 99-00 Si harness, how can you tell? (EE_Chris)
yes i'm talking about the cx/dx harness.
Old 01-03-2005, 12:05 AM
ek_b16's Avatar
Thanks!
For the last time man..This is a si harness and the ecu wasnt part of the deal. If you can bring back the pm's its stated on there. The harness came out of my b16a2 motor that i couldnt use becuase its obd2b.. I only sold it to you because i used a 96-98 ex harness..Use it and i swear i'll work. End of all your concerns.. Period..
Old 01-03-2005, 12:13 AM
ek_b16's Avatar
reference pic per Kat</TD></TR></TABLE>
This info is correct.. Plus the only difference from the obd2b ex harness is that the si vtec wires are longer and i believe the map wire... other then that there almost the same.
Rhetoric
07-16-2014 04:07 AM
Tarzan
05-15-2011 09:42 AM
DurrtyracingMIA
04-21-2008 08:15 PM
HATCHingMN
14
04-03-2007 04:19 PM
sumo
10-17-2004 08:52 PM
Quick Reply: 99-00 Si harness, how can you tell?
