Fitment Problem
Old Dec 14, 2004 | 05:50 AM
SpoolFedEF's Avatar
Default Fitment Problem
I'm having a problem with my b-series motor mounts in my 91 civic, in putting in a b18a1... the front and the rear mounts are giving me some trouble... mostly the rear mount. Its about 2 1/2 inches to the left... the transmission bracket is not lining up at all with the mount and i dont know what the problem is... i bought the kit for any b-series swap into a 88-91 civic/crx... it just doesnt make sense... does any one have a rear mount that will work for me?
Old Dec 14, 2004 | 05:23 PM
locash's Avatar
Default Re: Fitment Problem (SpoolFedEF)
I would check with the manufacturer of the mount kit.. Although, you could post a picture and we might be able to figure out your problem..
Are you using the correct rear mount bracket?
Old Dec 15, 2004 | 12:18 AM
dirtydisaster's Avatar
yeah i'm doin a obd1 gsr into a 90 hf crx, got the efb1 hasport, got the two side mounts on, can't get the 90' integra rear engine bracket to line up with the rear mount. they're lined up left to right, but up and down, the engine is too high, about 3/8 of an inch. I also noticed that the driver side of the engine is a little bit higher than the passenger side. I was thinking maybee if I shim the driver side mount would it set the rear mount. any knowledge would be appreciated.
Old Dec 15, 2004 | 08:44 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolFedEF &raquo;</TD></TR><TR><TD CLASS="quote">the front and the rear mounts are giving me some trouble... mostly the rear mount. Its about 2 1/2 inches to the left...</TD></TR></TABLE>
Did you move the rear mount over to the other set of bolt holes on the rear cross member?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolFedEF &raquo;</TD></TR><TR><TD CLASS="quote">the transmission bracket is not lining up at all with the mount and i dont know what the problem is...</TD></TR></TABLE>
Most kits eliminate the front tranny mount all together and rely on the other 3 only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolFedEF &raquo;</TD></TR><TR><TD CLASS="quote">i bought the kit for any b-series swap into a 88-91 civic/crx... it just doesnt make sense... does any one have a rear mount that will work for me?</TD></TR></TABLE>
What brand of kit is it?
Old Dec 15, 2004 | 08:48 AM
Default Re: Fitment Problem (dirtydisaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtydisaster &raquo;</TD></TR><TR><TD CLASS="quote">yeah i'm doin a obd1 gsr into a 90 hf crx, got the efb1 hasport, got the two side mounts on, can't get the 90' integra rear engine bracket to line up with the rear mount. they're lined up left to right, but up and down, the engine is too high, about 3/8 of an inch. I also noticed that the driver side of the engine is a little bit higher than the passenger side. I was thinking maybee if I shim the driver side mount would it set the rear mount. any knowledge would be appreciated.</TD></TR></TABLE>
Have you completely tightend the other 2 mounts mounts down? Try loosening them up to give yourself some slack and then you "should" be able to get the rear mount lined up. Tighten it down first, not fully though and see if that works. If so, torque them all down to spec.
Old Dec 15, 2004 | 07:55 PM
Default Re: Fitment Problem (VTECVillain)
thanks worked perfectly.
Old Dec 16, 2004 | 11:21 AM
SpoolFedEF's Avatar
1. no, it wont fit, i can see the other two bolt holes, but the mount wont fit right...
2. yeah i guess its not nessecary but i wnted to use it.
3. it is an HCP set
thanks for the help
Sammy Po
Jan 10, 2010 09:54 PM
tsopres
Mar 28, 2007 06:32 PM
Bob_760
Sep 7, 2006 08:50 PM
crxhybrid1320
Aug 28, 2004 08:46 PM
88' CRX ZC
Aug 6, 2002 07:11 PM
