95 Accord Manual to Auto swap H22... engine not sitting level?
95 Accord Auto to Manual swap H22... engine not sitting level?
I did an auto to manual swap on my 95 Accord...used all Accord Mt mounts and brackets with prelude driver side mount. Bolted everything up and my engine does not sit level...the drivers side looks about and inch higher than passengers side. Also I used my Accord AC and the pulley is like 1/2 inch from the frame and crankpulley is close too.
Wondering if anyone else has had this problem????
Modified by sinister2c at 12:51 PM 12/9/2004
Banned
Re: 95 Accord Auto to Manual swap H22... engine not sitting level? (sinister2c)
Question....
I have a 1997 Accord EX Auto and I am looking to swap in an H22 w/ 5 Speed.
You've done this. What mounts/ brackets will I need? I've been told I need to remove the passanger-side trans bracket (Welded to the frame) and replace it with the 5 Speed Accord bracket... Please break it all down for me.
Which motor mount and which bracket in each location?
A million thanks!!
A million thanks!!
Banned
Re: (v4lu3s)
I can do either...
If I drill which mount and bracket do I use? Auto or Manual Accord or Prelude?
Which rear (back of motor) mount and bracket did you use? Auto or Manual Accord or Prelude?
Which Driver Side mount did you use? Auto or Manual Accord or Prelude?
The reason your motor is sitting that way is because you need to change the motor mount bracket that is welded to the car from auto to stick then the motor will sit fine.
sinister2c
10-04-2006 02:54 PM
dutchman5
12-18-2005 12:13 AM
JBk24crx
04-16-2005 01:35 PM
