d15b
Old Dec 3, 2004 | 04:15 AM
gutted-dx's Avatar
Default d15b
Is there only one d15b for obd1 or did they make one for obd0.
What will i need to swap a d15b into a 89 STD (Dual point) hatch back
Modified by gutted-dx at 7:56 AM 12/3/2004
Old Dec 3, 2004 | 08:27 AM
VTECVillain's Avatar
Default Re: d15b (gutted-dx)
There are many versions and series of the D15B - OBD0, OBD1 and OBD2, nonVTEC, VTEC, etc. Any typical D15B will bolt directly into your hatch as long as it has the correct upper driver's side mount bracket, if not you can reuse your stock one. You can reuse your DPFI manifold, wiring and ECU although an MPFI conversion (use 88-91 Si distributor, ECU and a little wiring) would be much better. It would be a good idea to get an 88-91 DX/Si 5spd tranny as well although the 4spd will bolt right up and work no problem.
Old Dec 6, 2004 | 04:18 AM
gutted-dx's Avatar
Was there ever a D15b in a 88-91 crx or civic
Old Dec 9, 2004 | 04:37 AM
gutted-dx's Avatar
ttt
C_R_X_V_T_E_C
Feb 18, 2007 06:15 PM
slow99gsr
Apr 29, 2006 05:39 PM
gnar kill
Nov 15, 2004 06:35 PM
hondahybrids
Jul 8, 2004 02:42 PM
