CRX W/B16 Help!
wiring trouble w/CRX HF w/B16
Ok.....Will the hasport conversion work? its $79 and how do you install it? Thanks alot
Modified by TeaminlineB16 at 12:12 PM 12/17/2004
Re: wiring trouble w/CRX HF w/B16 (TeaminlineB16)
yes, it will work. you feed the loom through the same hole in the firewall that the amin harness goes through. pin the wires into the ecu as shown in the diagram/instructions. simply plug in the connectors to the sensors/switches on the engine accordingly.
