Rear Bracket help
Old Dec 14, 2004 | 02:48 AM
98civic94gsr's Avatar
Default Rear Bracket help
I got a 98 civic hx with jdm gsr motor going into it. I can get the engine to sit in place and get all the mounts hooked up except for the rear bracket that goes from the rear mount to the engine/tranny. I've been searching and searching and I believe I need the bracket off of a 99 civic si. I just want to know if this is correct or can I somehow squeeze my gsr rear bracket in thier that came on the gsr motor.
If anyone has what I need let me know, also need an injector for a 94 integra gsr motor.
Old Dec 14, 2004 | 07:14 AM
Trey's Avatar
25 Year Member
Default Re: Rear Bracket help (98civic94gsr)
Yes you need the Si rear bracket.
50827-S04-N10
More EK swap info in my sig.
Old Dec 14, 2004 | 10:12 AM
Default Re: Rear Bracket help (Trey)
Thanks for help.
Do you bolt the bracket to the motor and then drop it in the car. Or do you bolt the bracket to the motor mount and lower the engine in place?
Thanks
98civic94gsr
Old Dec 14, 2004 | 11:18 AM
dohcdelsol93's Avatar
I bolt the bracket to the engine and tranny then rais it into the car, bolting the rear mount in first do not tighten down until all are bolted in
Old Dec 14, 2004 | 02:44 PM
Default Re: Rear Bracket help (dohcdelsol93)
So you put the engine in from underneath? Do don't lower it in to the car?
Thanks
Aaron
Old Dec 15, 2004 | 04:58 AM
I do most of my work on a gravel drive way so it's easier for me to put the car onto stands and keep it stationary. I raise and lower the engine/tranny assy out of and into the car using a large transmission jack(one with saftey restraint chains).
Works very well.
Old Dec 21, 2004 | 02:47 AM
I found the bracket I need on hasport. Now all I need is a fuel injector and the senesor underneath the intake manifold that screws into the block. If anyone has one let me know.
thanks
Old Dec 21, 2004 | 04:25 AM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr &raquo;</TD></TR><TR><TD CLASS="quote">I found the bracket I need on hasport.</TD></TR></TABLE>
You do not need an aftermarket HASport bracket, the bracket you need is at your Honda dealership, from a 99-00 Si as "Trey" explained.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr &raquo;</TD></TR><TR><TD CLASS="quote">Now all I need is a fuel injector and the senesor underneath the intake manifold that screws into the block. If anyone has one let me know.</TD></TR></TABLE>
I have a set of 4 fuel injectors from a 1995 JDM B18C, the same as what you are needing. I don't wanna sell just one, but I will sell the whole set for cheap. PM me if you are interested.
Old Dec 21, 2004 | 07:44 AM
Default Re: Rear Bracket help (The Clash)
Clash
If I can't find the 99-00 si bracket then the hasport bracket will have to work.
I can't e-mail or private message you so you can e-mail me at raptoraja@yahoo.com
How much ya want for those injectors...35 bucks?
Let me know
Thanks
ryanevansoh
Jan 24, 2009 01:18 AM
oem_certified_accord
Dec 1, 2007 06:54 PM
sanegb16
Sep 5, 2007 01:41 PM
streetracerof06
Oct 28, 2005 09:53 AM
GarageTech
Mar 11, 2005 09:43 PM
