B18 engine harness HELP!!
Old Dec 11, 2004 | 07:44 PM
SpoolFedEF's Avatar
Default B18 engine harness HELP!!
I'm doing a b18a into my civic std hatch, and the wiring harness is not matching up on any of the main connectors... what do i need to do to get the wires to clip together.. (d-series dash harness with a B-series engine harness...) very confused PLEASE HELP!!!
Old Dec 11, 2004 | 08:53 PM
v4lu3s's Avatar
RTFM
remove the plugs from the end of the b series harness and repin the wiring into the civic plugs.
Old Dec 12, 2004 | 05:31 AM
VTECVillain's Avatar
Default Re: B18 engine harness HELP!! (SpoolFedEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm doing a b18a into my civic std hatch, and the wiring harness is not matching up on any of the main connectors... what do i need to do to get the wires to clip together.. (d-series dash harness with a B-series engine harness...) very confused PLEASE HELP!!!</TD></TR></TABLE>
The problem is you have an 88-91 Civic STD which is DPFI. Even if you tried using an 88-91 Civic/CRX Si engine harness it will not plug in because the main connectors at the stock towers are different for the DPFI and MPFI models. The easiest way to do the swap is to reuse your stock STD harness and salvage the necessary wiring (injector wiring, clips, and resistor box wiring) from the B18A harness. The other way (I highly suggest you know what you doing and have 2 Helms electrical manuals handy) is to completely unpin the shock tower connector plugs on the Integra harness and repin the Civic STD plugs on it. You MUST do the MPFI wiring to the car on the chassis side regardless of which method you choose.
yellowcanary.
Apr 18, 2015 11:47 PM
brandonEM1
Engine Management and Tuning
Nov 24, 2013 04:21 PM
Dethbox
Dec 14, 2011 08:24 PM
91CRX-T
Aug 17, 2011 01:16 PM
