mini me problems
Old Dec 2, 2004 | 05:33 PM
egizzle8
Guest
Posts: n/a
Default mini me problems
I'm having some problems with a minime I made yesterday. I'm using a C8 shortblock with a Z6 head and using the Z6 timing belt. Now the EG hatch that it went into just had a bad oilpump and main seal so I found a whole CX swap(longblock, tranny, axles,ecu, mounts etc...) for $20 so I ain't complaining. Now were both guessing that the timing is off since it's only firing on 1 cylinder and the car ran fine before and the harness wasn't altered in anyway and was a direct swap. It cranks but doesn't turn over and start like it's just on the urge to. Then we tried a couple more times trying different plug wires and ended up fouling the plugs. I'm not getting any CEL's and I'm guessing it's just one tooth off or so so nothing is binding or making contact. Help. Another friend of mine told to to use a Y7 cam gear if I'm not gonna use a adj. gear right away with the Z6 head and not to use the Z6 cam gear. Anyone heard this?
Philthy75
Aug 25, 2013 12:08 PM
toolbox21
13
Jul 6, 2009 09:40 AM
EARLdaSQUIRREL
May 7, 2009 02:14 PM
TMC_EF
Jul 22, 2008 06:25 PM
