Anyone have an EG gauge cluster pinout?
I just did a swap on a '94 CX Civic hatch and the coolant temp gauge is not working.Before I go out and buy a new one,I want to check all of the pins at the plug to make sure they're where they are supposed to be.I believe the plug is the c302 plug,but I may have gotten it confused with the c101 plug.I need the pinout for those plugs and for the cluster.If anyone has these I would appreciate if you could get me a copy of that.
Thanks!
Thanks!
Re: Anyone have an EG gauge cluster pinout? (JDMotive)
Civic Left Side Grey Plug (12 pins)
1. YEL/WHT - Fuel gauge
2. YEL/BLU - Vehicle speed sensor
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. WHT/BLU - Charge
6. YEL/RED - Oil pressure switch
7. -
8. BLU - Tach signal
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
Civic Right Side Grey Plug (10 pins)
1. RED/GRN - High beam indicator
2. GRN/RED - E-Brake signal
3. -
4. -
5. GRN/ORG - Check engine indicator
6. BLK - Ground
7. YEL/GRN - Coolant temp
8. YEL - Hot
9. GRN - Trunk switch
10. BLU/WHT - Seat belt
5. WHT/BLU - Charge
7. -
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
3. -
4. -
6. BLK - Ground
8. YEL - Hot
Re: Anyone have an EG gauge cluster pinout? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">VTECVillain, you use that crazy thing in the top right corner named "search"? </TD></TR></TABLE>
Rarely... I just use that crazy thing called "memory" or "saved files on my computer"
Re: Anyone have an EG gauge cluster pinout? (VTECVillain)
Thanks a million Vtecvillian!
BTW...this is the first out of a thousand times that I didnt use search.Just in a rush.
One more thing...
There is another plug under the dash..all of the ignition and cluster wires run through it.I believe it is the c302 or c101 plug(get those mixed up).You wouldnt happen to have the pinout for that,would you?
Thanks!
Thanks!
skribblah
12
09-15-2003 09:30 AM
eric.
10-17-2002 04:30 PM
