Compression of an ls-vtec ???
Old Dec 15, 2004 | 06:16 AM
BIGGINS LS-VTEC's Avatar
Default Compression of an ls-vtec ???
Does any one know the compression for and ls vtec with a stock b16a head and a stock b18b1 bottom end ? Any information would help or if u have the formula so that i could compute it my self for future builds thanks.
What would the compression ration be if i put b16a pistons in the ls bottom end on the ls rods and crank and ran that head ? Any help is greatly appriciated sorta in a rush to get in to car but i need to know this so that i don't get to high if compression if i decide to got wiht a higher compression pistons..........thanks
Old Dec 15, 2004 | 07:41 AM
Phatch99's Avatar
Default Re: Compression of an ls-vtec ??? (BIGGINS LS-VTEC)
go here...... they have a compression caculator.
http://www.c-speedracing.com
Old Dec 15, 2004 | 08:28 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGINS LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Does any one know the compression for and ls vtec with a stock b16a head and a stock b18b1 bottom end ?</TD></TR></TABLE>
The compression will be lower than a stock B16A. Using a completely stock B18A/B block, stock B16A head and an OEM 3 layer headgasket will put compression in the 9.5:1 - 9.6:1 range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGINS LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">What would the compression ration be if i put b16a pistons in the ls bottom end on the ls rods and crank and ran that head ?</TD></TR></TABLE>
If you use the PR3 B16A pistons, it will raise the compression significantly. It will be around 11.3:1 - not a really good idea for a stock bottom end and little to no tuning...
Old Dec 16, 2004 | 09:04 AM
Default Re: Compression of an ls-vtec ??? (VTECVillain)
thanks thats a big help
Adam_b16a
Nov 30, 2009 08:29 AM
masquzy1080
Nov 23, 2007 08:45 PM
migs
Aug 16, 2006 07:20 PM
Pandahatch
Jun 6, 2004 10:43 PM
Cractos
Mar 18, 2004 03:45 PM
