will 95 gsr axles and half shaft work in a crx si swap?
like the topic says i have everything to put my motor in the car but dont wont to get stuck on axles my car 91 crx si the axles out of a 95 teg gsr
the motor 95 b18c1 and hydrolic gsr transmission
please help ive heard 90 to 93 teg axles but went to parks auto and they dont have the half shaft and they are to short. hate being without a ride
chris
chris
Re: will 95 gsr axles and half shaft work in a crx si swap? (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey »</TD></TR><TR><TD CLASS="quote">if you are using the hydro trans and 94-intermdiate shaft then yes you can use the 94-gsr axles. </TD></TR></TABLE>
Correct. Even if you are using a cable tranny you can still use the 94+ axles as long as you change the driver's side tranny seal to a 94+ seal.
Rywire
10
05-05-2004 12:21 PM
