Ek..K20a2 ...wiring info...help...
...does anyone have ...how to ...or what to do ...by joining the charging harness with the to the k series harness....i need help or if you have a homemade schematic....some how .....give me a hint
Re: Ek..K20a2 ...wiring info...help... (CRX20SI)
https://honda-tech.com/zerothread?id=938441
https://honda-tech.com/zerothread?id=921343
next time search
also check out http://www.k20a.org
next time search
Re: Ek..K20a2 ...wiring info...help... (adirondackR)
look...I pulled out the k20a2 would be able to use the two e plugs except the the c101 plug which has to be wired to my ek c101 plug right ....tell me if im correct and how many more mods would have to be done without cutting and solder.... which is no problem ....and the charging harness which has to be wired into my ek charging box..........alternator...and starter....but what im worried about is the one on the drivers side which wires from the k engine into the right sensors .......Am I close
You sure buy the Hasport or Hybrid-Racing harness. Either harness starts up first crank. No check engine lights either!! Great ****...+ no headaches!!
GripFactoR
11-21-2003 02:36 PM
