diff
Old Dec 15, 2004 | 07:44 AM
AutoLab's Avatar
Default diff
it appears the axle length is ok afterall. When the car is on the ground and the spindle nut is off we have around 5/8" end play.
The case is stamped showing that the trans is non LSD, which is not what we ordered. It appears to have an LSD in it though, as you can see through the diff and when you turn one wheel the other turns in the same direction.
We are only assuming that the owner in japan put an aftermarket diff in the trans and we're just hearing it when we turn. I have no experience with aftermaket Honda diffs but this sounds a bit much. It sounds like it has a welded diff or spool in it.
hmm
Old Dec 15, 2004 | 08:42 AM
Kamin's Avatar
Default Re: diff (AutoLab)
whats the rest of the story? is it making noises when you turn? sounds like it could be a 2way type differental.
Old Dec 15, 2004 | 07:35 PM
AutoLab's Avatar
Default Re: diff (Kamin)
turns out the trans had a Kaaz installed when it was in Japan.
-bill
laziebun
Transmission & Drivetrain
16
Sep 9, 2008 08:49 PM
civicomax
Aug 21, 2007 04:22 AM
5poonhatch
12
Jan 13, 2007 05:47 PM
servion
Jul 1, 2003 11:59 AM
