Doing a Great motor swap and build need help??????????
I am building my summer racer and I just picked what setup I am going with a spark racing street block and a head from them also.This is all going into a 94 auto hatch I need to know what I missed thanks guys. dont hold back on the comments
Street Stage 2 block from spark racing
P&P head from spark racing
Type R cams
Head gasket
Header
Ls wiring harness
Ls transmission--got it cheap
Type R valve cover from modacar red
Short Shifter
clutch pedal
shift linkage from GSR
Motor Mounts
Alternator
Edelbrock Manifold
Ls throttle body
All MSD ignition
p28 chipped
Anything I missed Please Let me know Thanks!!!!!!
Type R cams
Head gasket
Header
Ls wiring harness
Short Shifter
clutch pedal
Motor Mounts
Alternator
Edelbrock Manifold
Ls throttle body
All MSD ignition
p28 chipped
Re: Doing a Great motor swap and build need help?????????? (4doorhybrid)
if you are using type r cams, i'm assuming your head is a either a b16a/b or a b18c1/5 (or a b17a). all of these heads are vtec enabled. the reason i brought this up is you are using a ls harness which does not have neither of the vtec plugs. hope that helps. sounds like a kick *** setup tho.
p.s. you might find the ls gearing to be a little long for a race (all-motor) application.
dohc_profile
09-19-2006 02:39 PM
slodel
12
12-11-2004 07:59 PM
