Tired of searching-h22a swap into an eg civic
i just need some links or a good write up of a h22a into a 93 eg civic. i searched for a while now but have not found what i am looking for. thanks in advance
Re: (allmotorEG-SI)
i already have a full swap, radiator, thin fan, axles, and mounts. i just need to know some info on what not to do and what to do so i can do it right the first time. pretty much i am looking for instructions on how to do it properly and what i should avoid, expect etc.
fyi i have done mpfi swaps, 2 turbo installs, h22 into an accord and several b and d series swaps into eg's and ef's. and i have owned 3 of these. i do all the work myself with a friend or two. so i am just looking for some heads up and encouragement. i just want to fully know what i am getting into before i pull the motor out of my daily driver. i want to do the swap in 1 to 2 days max. thanks
aw, well i glanced at the FAQ and it seems like it has pretty good instructions. It should be able to help you with what you need to do. YOu seem hesitant to do so becuase its your DD. If thats the case then wait until you have more time, like 3 day weekend or something.
