ecu pin out
ecu pin out
Any body got a picture showing the pin locations on the ecu for a 93 civic hatchback with a 1.5l non vtec. just did a swap and need to wire in vtec,iab,knock sensor etc. installed a b18c jdm.
Re: ecu pin out (turbogixxer)
Thanks a lot for the picture its great but i just want to make sure that its a picture of the ecu for the 1.5l non vtec engine because i am trying to trace a red wire coming out of the ecu. again thanks a lot.
Re: ecu pin out (jess press)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jess press »</TD></TR><TR><TD CLASS="quote">Thanks a lot for the picture its great but i just want to make sure that its a picture of the ecu for the 1.5l non vtec engine because i am trying to trace a red wire coming out of the ecu. again thanks a lot. </TD></TR></TABLE>
In that case you'll probably need the complete schematics from the Helms manual. If you don't feel like buying one, look around I'm sure you can download them online.
LSTEG96
02-22-2009 08:16 PM
