obd2 D16y7 into 92 CX Need Help!!!
I'm helping a friend swap a d16y7 out of a 96 dx into his 92 cx. What all is needed for the conversion as far as wiring goes? Any help is really appreciated, thank you!
Re: obd2 D16y7 into 92 CX Need Help!!! (96MidoriHatch)
No wiring at all, it's a direct drop-in but you need to reuse parts from the CX and keep it all OBD1. You don't want to use the Y7 manifold, mainly the 3 wire IACV is what get's you. The CX intake manifold sucks (very small ports and TB) but you'll have to reuse it complete unless you can get one from a 92-95 DX, EX or Si. You will reuse the CX distributor, manifold with injectors and all sensors, the alternator and the engine harness. That's it and it will bolt in without any additional or changed wiring.
Re: obd2 D16y7 into 92 CX Need Help!!! (The Clash)
thanks thats exactly what i was looking for! I'm gonna go get a new intake mani gasket right now
