Double checking before i start my swap.
Im putting an LS obd-1 motor in my EK. I have a conversion harness to use the obd-1 ecu. Im using a combination of all stock mounts, integra axles and shift linkage. And I use the civic wiring harness. I have a crv bracket for the ac and i have and obd-2 distributor. What else do i need to know? Thanks.
Re: (jaybee)
also need the 99 si timing belt bracket mount since the integra is straight and the ek's is on an angle. its a bitch to change so might do it now.
