obd1 dizzy on obd 2 vehicle??
searched and found that obd2 will work on obd1 vehicle but could it work the other way around(obd1 dizz on obd2 vehicle)?? and is it posible to use obd1 injectors on an obd 2 car?? both have the same amount of wires running out of it so i figured just swap plugs...is it really that simple?? thanx all
Re: obd1 dizzy on obd 2 vehicle?? (fiftee_su)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiftee_su »</TD></TR><TR><TD CLASS="quote">searched and found that obd2 will work on obd1 vehicle but could it work the other way around(obd1 dizz on obd2 vehicle)?? and is it posible to use obd1 injectors on an obd 2 car?? both have the same amount of wires running out of it so i figured just swap plugs...is it really that simple?? thanx all</TD></TR></TABLE>
yes you can use OBD2 injectors/alternator/distributor in an OBD1 vehicle & vice versa as long as you wire in the respective plugs for those parts. All you gotta really do for this, is to color match the wires to the respective plugs.
