automatic to manual change
Old Dec 16, 2004 | 12:12 PM
v-tec maz's Avatar
Default automatic to manual change
hi everyone i just wanted to ask how much work does it take to change the automatic to manual conversion after you get the manual swap. does it cost a lot?
i just found a very good deal on a automatic civic coupe but its automatic, im thinking if its not very hard i do a d15 sohc vtec. tanx
Old Dec 16, 2004 | 07:16 PM
locash's Avatar
Default Re: automatic to manual change (v-tec maz)
Other than the obvious stuff, ie: changing the pedal assembly, using the Hasport EGAMH conversion mount, putting in the clutch master cylinder/slave cylinder/lines, there is the not as minor tasks such as obtaining a section of the exhaust tunnel from a 5 speed car and grafting it into your car, and bypassing the neutral safety switch. Other than those things, the swap is actually pretty straightforward.. Figure about 200-400 dollars worth of these extra things to get the job done..
Old Dec 18, 2004 | 12:22 PM
v-tec maz's Avatar
Default Re: automatic to manual change (locash)
good ifo i need some pics too
v-tec maz's Avatar
bump!
Old Dec 18, 2004 | 01:57 PM
v-tec maz's Avatar
people i really need your help. come on. plz its a good deal that i found i cant wait long time. some one else might pick the car up
Harmsown
Acura TSX
Dec 29, 2014 09:28 PM
xkrazyxjbrkerx75
Apr 21, 2009 10:18 AM
unxpected323
Transmission & Drivetrain
Sep 13, 2008 11:11 AM
EK9Tune
Feb 19, 2007 01:26 PM
adamvogt28
Oct 5, 2006 07:46 PM
