HELP!!! Engine missing at 4000 after swap
Old Dec 9, 2004 | 10:20 AM
NitrousB.I.G.'s Avatar
Default HELP!!! Engine missing at 4000 after swap
I just barelly got back from another shake down run after swapping in a 95 GSR into my 93 civic Si. Everything was going ok at first but I did notice a slight miss above 3000 rpm, when I gave it some more it really began to studer at 4000 rpm. I kept driving in the lower rpm range and the studdering or missing started to get worse. It started to stall everytime I came to a stop, although it did start up right away but was a bitch to get the car rolling again. It even started studdering in the lower rpm range and I was barely able to get it home. My question is what the hell do you guys think it is, where should I start? I just recently replaced the ignitor with a known good one, the ecu works perfectly in my bros car and I just installed a new coil. I dont think that it is the fuel system because the A/F seemed ok. Help me please!!!!!!!!!!!!
Modified by NitrousB.I.G. at 10:33 PM 12/9/2004
Modified by NitrousB.I.G. at 3:19 AM 12/10/2004
Old Dec 9, 2004 | 02:23 PM
Default Re: HELP!!! Engine missing at 4000 after swap (NitrousB.I.G.)
Help!
Old Dec 9, 2004 | 05:51 PM
I just pulled the plugs and they look great. It definatly wasnt too rich or detinating. I forgot to mention that I wasnt throwing any codes. WTF?
Old Dec 10, 2004 | 04:33 PM
2lua's Avatar
you might had the tps and map plug reverse.
Old Dec 11, 2004 | 04:55 PM
Default Re: HELP!!! Engine missing at 4000 after swap (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">you might had the tps and map plug reverse.</TD></TR></TABLE>
That might be it. Thankyou
Old Dec 12, 2004 | 07:25 AM
primeredbeast's Avatar
if its missing it sounds like its in the dizzy
Old Dec 12, 2004 | 03:55 PM
I just checked the TPS and the MAP connectors and they are in the right spot. The thing that is really stumping me is the fact that it got worse the more i drove it. Could the ignitor be doing this? I had to replace the ignitor and replaced it with the one from my old motor (which was working before the swap). I definatly think that it has to be something to do with the ignition because it was making a popping noise when it was missing.
Old Dec 12, 2004 | 05:03 PM
Silverhatch's Avatar
my car did that and i had the the plug on the head below the vtec sylnoid and a oil sensor switched...
Old Dec 14, 2004 | 08:47 PM
Default Re: (Silverhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverhatch &raquo;</TD></TR><TR><TD CLASS="quote">my car did that and i had the the plug on the head below the vtec sylnoid and a oil sensor switched...</TD></TR></TABLE>
Ill give that a try when I get over this damb cold.
Old Dec 20, 2004 | 11:58 AM
Default Re: (NitrousB.I.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousB.I.G. &raquo;</TD></TR><TR><TD CLASS="quote">
Ill give that a try when I get over this damb cold.</TD></TR></TABLE>
wasnt that, im gonna try another ignitor
phenixkingrde
Aug 11, 2011 12:27 PM
gsrauto98
20
May 21, 2010 08:59 PM
dboz3403
Sep 23, 2007 03:42 PM
dboz3403
Sep 23, 2007 03:41 PM
