k24 complete swap to gsr body will it fit?
i was planning on getting a k24 swap and take out my gsr motor but my question is will it fit into my 98 gsr engine bay and will i have any body problems if i modify the body after?
Re: k24 complete swap to gsr body will it fit? (acdracing)
The kseries motors fit with the correct mounting kit. What do you mean by changing the body?
Also do a quik seach and you will find alot of pics of the swap...
Re: k24 complete swap to gsr body will it fit? (triple_s1x)
Yes, like said before the swap is possible if you use the right mounts. As for body problems the only thing I can think of would be that you DO have to cut a body motor mount OFF the car to complete the swap. As for wiring if you use the HASPORT wiring or the Hybrid-Racing harness both CAN be turned back to stock if nessacary.
Another thing you will have to address is the shifter. More than likely, you will have to cut a BIG hole out of the tunnel where the factory (or B-series) linkage bolts up. In my opinion if you do the swap its a "K-swap car" for life....but defanatly nothing wrong with THAT!!
Modified by fabworxs at 4:18 PM 12/13/2004
Re: k24 complete swap to gsr body will it fit? (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey »</TD></TR><TR><TD CLASS="quote">The k24 sits almost 20mm taller too. Will it clear the hood?</TD></TR></TABLE>
in a DC2 chassis with Hasport mounts, Yes
supanatural
01-15-2004 10:56 AM
