heed hepl fast b18c1 crx
I just did the swap, trying to start the car. I hook up the battery and the battery light and door light come on in the car, the buzzer goes off in the car and the honr blows. All without the key in the ignition. Maybbe a bad ground on the neg battery cable. It's to the trany mount. SHould a bad ground cause all those problems w/ the key off? thanks any help appreciated.
Re: heed hepl fast b18c1 crx (dirtydisaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtydisaster »</TD></TR><TR><TD CLASS="quote">thanks i figured it out. right on</TD></TR></TABLE>
So what was the problem and what did you do to fix it?
Re: heed hepl fast b18c1 crx (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
So what was the problem and what did you do to fix it?</TD></TR></TABLE>
I was kinda delerious while I was putting the engine in, and some how I didn't figure out that the ground's that would go onto the thermostat housing were a ground. For some reason I thought it went to the starter. Big Mistake.
hondascientist
06-28-2005 06:36 PM
