obd2 distributor ??
Old Dec 19, 2004 | 01:05 AM
FermiumHalo's Avatar
Default obd2 distributor ??
So I have a 98 gsr distributor, running off my obd1 p72 ecu. Everything seems to be working fine. I thought I needed a obd1 distributor, whats the difference?
Old Dec 19, 2004 | 05:48 AM
The Clash's Avatar
Default Re: obd2 distributor ?? (FermiumHalo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FermiumHalo &raquo;</TD></TR><TR><TD CLASS="quote">So I have a 98 gsr distributor, running off my obd1 p72 ecu. Everything seems to be working fine. I thought I needed a obd1 distributor, whats the difference?</TD></TR></TABLE>
Internally they are the same, only differences is the plugs.
Old Dec 19, 2004 | 09:25 AM
Default Re: obd2 distributor ?? (The Clash)
Its in my 95 civic, so I'm asumming that the engine I have since it has a 98 harness allowed the distributor to work. How about the main plugs at the strut towers... they still fit even though my car is a 95 and the motor is a 98... how is that so any harness from 94 - 2000 will plug into a 92-95 civic?
thanks
Old Dec 19, 2004 | 10:22 AM
EKB18BPR3's Avatar
i have a 98 EK dx with 94 b18b and im wondering the same thing. my distributor went bad so when i was searching to buy one for the 94 OBD1 distributor, i noticed it wouldnt fit due to the plugs. so i guess im gonna need obd2 distributor with one plug because thats what the harness will fit at....im getting myself confused...
Old Dec 19, 2004 | 03:01 PM
Default Re: obd2 distributor ?? (98B00STED)
yeah my distributor is a one plug obd2 from a 98 gsr. But some how the harness in the 98 gsr engine plugged into my 95 chassis... I guess since u have an ek u need a obd2
Old Dec 20, 2004 | 04:39 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Clash &raquo;</TD></TR><TR><TD CLASS="quote">Internally they are the same, only differences is the plugs.</TD></TR></TABLE>
You might be n0ob but you're right. The only thing that differs from the OBD1 and OBD2 distributors is the external plug style. OBD2B lack the RPM signal though.
Old Dec 20, 2004 | 04:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FermiumHalo &raquo;</TD></TR><TR><TD CLASS="quote">Its in my 95 civic, so I'm asumming that the engine I have since it has a 98 harness allowed the distributor to work. How about the main plugs at the strut towers... they still fit even though my car is a 95 and the motor is a 98... how is that so any harness from 94 - 2000 will plug into a 92-95 civic?</TD></TR></TABLE>
Even though the 96-01 Integra's are OBD2, their engine harness uses the same plugs and pinouts which just happen to cleverly be plug-n-play with 92-95 Civic's chassis harness (at shock towers). It makes putting any OBD1 or OBD2 motor into an EG be very easy. EK Civic owners don't have it so lucky...
Old Dec 20, 2004 | 04:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 EK dx with 94 b18b and im wondering the same thing. my distributor went bad so when i was searching to buy one for the 94 OBD1 distributor, i noticed it wouldnt fit due to the plugs. so i guess im gonna need obd2 distributor with one plug because thats what the harness will fit at....im getting myself confused...</TD></TR></TABLE>
You can use use an OBD1 distributor in an OBD2 chassis and vice versa. All you need to do is switch the plug(s) to make it plug-n-play.
VTECth1s
Jun 5, 2006 04:09 PM
lazykiwi
Oct 25, 2003 07:59 AM
b16 matt
Feb 10, 2003 06:46 PM
Blown90hatcH
Jun 15, 2001 10:31 AM
