im gonna b lookin at a h22 swapped eg,,tips on what to look for??
im gonna b lookin at a h22 swapped hatch soon,,and i dont know much about those ,,and how well they work in eg's..
id like to know things to look for ?
maybe to know that it was done right??
what common probs do people run into with the h22's into eg's???
thanks mike
thanks mike
Re: im gonna b lookin at a h22 swapped eg,,tips on what to look for?? (Wrath of VTEC)
Make sure the mounts they used are good quality. Engine sits straight in bay, etc
Wiring is always gonna be custom so make sure there are no short cuts like black tape instead of actual soldering along with shrink tubing.
Ask what ecu they are using and what tunning has been done. If there are any CEL's and why. If its a chipped ecu make sure its for an h22 not a B series engine.
Those are just a few things i can think of right now. Those things are basically what took me longest on the swap.
The most important thing however is the test drive/ visual inspection. I think this one is obvious
Re: im gonna b lookin at a h22 swapped eg,,tips on what to look for?? (94_HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH »</TD></TR><TR><TD CLASS="quote">Make sure the mounts they used are good quality. Engine sits straight in bay, etc</TD></TR></TABLE>
This is a definite must, should be top of the list. There are so many generic kits available now that might look good to the eye, but once they are installed you'll think WTF???
Definitely pay attention to the Check Engine Light (CEL) in the cluster. Make sure it comes on when you turn it over then goes out after a few seconds. Some people will remove the bulb or fake it by installing a relay so it comes on then goes off. If it's throwing codes, make sure they are willing to jump the harness and show you what codes are thrown and why.
If you can, check the axles for alignment - make sure they aren't at a sharp angle or bind. Also check for any tranny leaks. Aside from that, definitely take a good test drive. Make some really sharp turns at low speeds, things like that just to check for axle problems.
Re: im gonna b lookin at a h22 swapped eg,,tips on what to look for?? (VTECVillain)
hcp mounts,,,and runnin a uberdata,with p05 ecu,,vtec added
what kinda axels would u use if u had the swap done??
also,,
also,,what kind would u upgrade to,,,,i dont really plan on building the motor yet,,just try and safely run maybe 8 or so PSI
what psi can b run safely if tuned properly??
thanks mike
also,,
thanks mike
oem_certified_accord
08-03-2007 09:13 AM
