LS/VTEC Question!!
Old Dec 15, 2004 | 01:46 PM
SPOOLED's Avatar
Default LS/VTEC Question!!
Is the factory LS oil pump good enough to run a TURBO LS/VTEC set up for a few months. I'm sure this has been answered before but there are way too many search results on LS/Vtec to read all of them. I am going to build the motor and use a GSR pump then, but in the mean time any info will help. Thanks!!
Old Dec 15, 2004 | 04:51 PM
triple_s1x's Avatar
Default Re: LS/VTEC Question!! (SPOOLED)
Alrighty i'm 100% sure i read this somewhere, but i think the gsr and ls pump are the same pieces except the spring that controls the oil pressure. I heard of some people shimming the spring to increase the oil pressure output.
Old Dec 16, 2004 | 06:17 AM
endlesswinterco's Avatar
Default Re: LS/VTEC Question!! (triple_s1x)
im running the gsr for all motor, just take the time/money now and throw it in there to be safe.
Old Dec 16, 2004 | 08:57 AM
dohcdelsol93's Avatar
Default Re: LS/VTEC Question!! (RidinlowHatch)
If this is your first ls/vtec I'd suggest you read all of those threads. If you were going all motor ls/vtec you'd be ok with the ls oil pump, definatly upgrade if your doing turbo ls/vtec. all newer model b's have the same gear diameter but the spring pressure rate varies go with gsr/itr.
175Shot4Door
May 5, 2009 05:52 AM
-=ZAK=-
27
Jan 30, 2009 08:03 AM
vtecb18c
Jun 4, 2008 09:22 PM
CaptainMorgan
Oct 9, 2005 09:30 AM
GRIMEY.STREET.RACER
Jul 20, 2002 05:02 PM
