Possible V-Tec problem
Old Dec 3, 2004 | 06:29 PM
civicnar's Avatar
Default Possible VTEC problem
Ok guys this is for a friend of mine but he has a CRX with a 1st gen B16 and he had everything working properly for a while and then he was removing some wires and cut something that shorted out and fried his ECU. He bought a chipped ECU and now it won't go past 3000 RPM's but if he runs the stock ECU from the CRX it will run properly without VTEC but if he puts a VTEC Controller on the stock CRX ECU then it will only rev to like 3000 again so please help me out. Thanks
James
Modified by civicnar at 9:55 PM 12/5/2004
Old Dec 3, 2004 | 06:45 PM
Hapexamendios EJ8's Avatar
Default Re: Possible V-Tec problem (civicnar)
alright guys shall i start this one??... VTEC not V-Tec or vtech or v-tech
wheew, i feel better
Old Dec 5, 2004 | 12:53 PM
civicnar's Avatar
Default Re: Possible VTEC problem (Hapexamendios EJ8)
RRRIIIIIIGGGGGGHHHTTTTT OK anyone with any useful info other than what was stated by the genuis above.
Old Dec 5, 2004 | 06:26 PM
DOHCter's Avatar
try running 2 direct wires from the vtec solenoid (solenoid & pressure) to the computer. and make sure you ground the soleniod. sounds like theres something wrong with the wiring.
Old Dec 5, 2004 | 06:34 PM
VTECVillain's Avatar
Default Re: Possible VTEC problem (civicnar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnar &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys this is for a friend of mine but he has a CRX with a 1st gen B16 and he had everything working properly for a while and then he was removing some wires and cut something that shorted out and fried his ECU.</TD></TR></TABLE>
It's always a good idea to remove the negative battery cable when doing anything electrical to avoid things like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnar &raquo;</TD></TR><TR><TD CLASS="quote">He bought a chipped ECU and now it won't go past 3000 RPM's but if he runs the stock ECU from the CRX it will run properly without VTEC but if he puts a VTEC Controller on the stock CRX ECU then it will only rev to like 3000 again so please help me out.</TD></TR></TABLE>
The chipped ECU could be bad but it sounds more like a wiring problem to me. The reason it won't rev higher is because it is in limp mode. If the wires he originally cut were not repaired, I would start there and re-do that first off. From there, remove the VTEC controller and rewire any changes from that back to stock as well. If you don't know what you're doing, let someone else who does take a look at it before you end up doing anymore damage.
Old Dec 6, 2004 | 08:44 AM
civicnar's Avatar
Default Re: Possible VTEC problem (VTECVillain)
Do you think that he might have shorted something inside the solenoid maybe. I am not sure what all he has done to it but I will suggest to him that he run a wire directly to the ECU from the solenoid. Also are the solenoids interchangeable from B's to D's or does it have to be one for a first gen B. Thanks
James
Old Dec 6, 2004 | 03:12 PM
v.i.gsr's Avatar
Default Re: (civkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civkid &raquo;</TD></TR><TR><TD CLASS="quote">try running 2 direct wires from the vtec solenoid (solenoid & pressure) to the computer. and make sure you ground the soleniod. sounds like theres something wrong with the wiring. </TD></TR></TABLE>
I agree thats how mine is set up, and it works perfect.
DarikDisease
Aug 26, 2008 01:29 PM
ImPuLsIvE
Sep 18, 2007 08:16 PM
slammed_92_accord
Apr 27, 2006 07:46 PM
whitehf
26
May 26, 2005 11:00 AM
digitalhav0c
Apr 9, 2002 11:05 AM
