crank angle sensor problem in ek
ok i went through search and i really cant find useful info on this,i have a 97 ek lx,just swapped in a 98 ls motor and on the ls motor the crank sensor has 2 wires and the civic harness has a 3 wire plug.how do i rewire this (pin#,wire colors,etc) thanx ahead of time
i have the same problem, i just swapped in a 00 b16a2 in my 97 ex and the b16a2 has a 2 wire plug and i have a 3 wire plug on my harness..... how would i wire this? any help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTL »</TD></TR><TR><TD CLASS="quote">i have the same problem, i just swapped in a 00 b16a2 in my 97 ex and the b16a2 has a 2 wire plug and i have a 3 wire plug on my harness..... how would i wire this? any help?</TD></TR></TABLE>
Get a B series Crank Fluctuation Sensor?
what i did was get a 2 wire plug from a gsr or ls and switched the plugs...just matched up the colors of the wires and tape up the extra wire which is brown/black...
and its not the crank angle sensor..its the CKF..crank fluctuation sensor...
jonathan13
Apr 10, 2009 08:24 PM
CTL
Mar 2, 2004 12:35 AM
