b16b in a eg
im going to swap a b16b into my 95 cx civic, questions i have are for people who have done this. did you change the injectors and distributor to obd 1 and change the ecu . what else did you have to do? any suggestions? i dont want to hear that i should get a different motor like a b18c,r i just want to know about these questions thanks. i did a search and didnt see this. nobody huh?
Modified by redegg at 8:38 PM 5/17/2003
from what ive seen in doin obd2 motors in obd1 cars....all you use from the motor is the manifolds, block and head...change the sensors, distributor, and injectors.....type r is the same as any other.....My friend had a B16b in his EK...it ran like a champ....good luck
Get the B18CR, if your looking for an R motor.....the B16B is still tq less and cost to much for what you get, not much more power than a regular B16. Go 1.8L.
you didnt read my post did you, not much more power than a b16 huh. b16a 160-168 , b16b - 185 lsd tranny with great gearing, high revs.
Modified by redegg at 3:31 AM 5/29/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG »</TD></TR><TR><TD CLASS="quote">from what ive seen in doin obd2 motors in obd1 cars....all you use from the motor is the manifolds, block and head...change the sensors, distributor, and injectors.....type r is the same as any other.....My friend had a B16b in his EK...it ran like a champ....good luck</TD></TR></TABLE>
what kinda 1/4mile times he run?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redegg »</TD></TR><TR><TD CLASS="quote">you didnt read my post did you, not much more power than a b16 huh. b16a 160-168 , b16b - 185 lsd tranny with great gearing, high revs.
Yes I did, go ahead waste your money. I know the hp ratings, but Honda needs Torque. You should get the 1.8L
threehonda
Aug 19, 2009 11:55 AM
SOHC_2_DOHC
Aug 5, 2008 04:20 PM
moleodonuts
Jan 9, 2005 02:12 PM
