need some help with an exhaust for crx swap...
ok here is the deal. Dont really wanna drive to an exhaust shop with open manifold and i didnt know if any company out there mass produced a bolt on catback system for the crx with a b series swap?
ANYONE??????
TIA
ANYONE??????
TIA
Re: need some help with an exhaust for crx swap... (maxxdout)
any crx exhaust will work on your car. thermal r&d,greddy,hks etc. just because you have a b16 doesn't have anything to do with aftermarket crx exhaust (unless your b16 has a s/c or turbo). i'd suggest the thermal exhaust VERY nice
Re: need some help with an exhaust for crx swap... (redEFnine)
ok good to know. I was unaware that the stock d series manifold was the same location and length as the b series, as well as the cat lining up with the new engine. But since you are saying that the lengths and positions of all of these are the same then there should be no problems...correct??
the header isnt always long enough to reach the cat. sometimes the del sol 4-1 does but it depends on the mount kit. unless you know how to weld your probably going to have to go to an exhaust shop. good luck
vtecn8ive
02-02-2005 12:49 PM
