gsr running lean
Old May 14, 2003 | 01:47 PM
Formula 1's Avatar
Default gsr running lean
ok i got the jdm gsr in a 00si i got a ecu code 1 ...o2 sensor but im wonderin how the o2 sensor can just blow could it be from running lean and how do i check if im runnin lean?
Old May 14, 2003 | 09:28 PM
b16ahybrid's Avatar
Default Re: gsr running lean (SikCivic)
o2 sensors go bad over time. you can chack the condition of your engine by pulling your plugs. They will tell you how your engine is runing.
Old May 14, 2003 | 09:48 PM
Formula 1's Avatar
Default Re: gsr running lean (b16ahybrid)
ok well the o2 sensor is new ...and plugs how is that supposed to tell me if im runnin lean?
Old May 15, 2003 | 06:42 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">ok well the o2 sensor is new ...and plugs how is that supposed to tell me if im runnin lean?
I take it you've never read plugs before.................
Well if your runing lean your plugs will have signs of detontion, and they will be chalky white, If your runing rich they will look fouled or black, good plugs should be grey in color.....
Old May 15, 2003 | 11:22 AM
Formula 1's Avatar
correct never read em...well thanx for the info
type-t
Nov 30, 2011 04:27 PM
1993eghatch
17
Jan 21, 2011 09:22 PM
Shonn
Oct 16, 2006 04:29 AM
98IntegraLSNonVtec
Aug 4, 2006 09:18 PM
