Code 36? On jdm p13
Old May 12, 2003 | 11:46 PM
jdm94h22acivic's Avatar
Default Code 36? On jdm p13
Hi I just got my jdm h22a dropped in tonight started on third crank. It has a check engine light so I diagnosed it and it showed code 36... I havent been able to find anything on a code 36 anywhere. Its a jdm p13 if that helps. Is this a real code or is my ecu wack. It also showed code 20 electrical load detector, if anyone has any info on how I could fix these problems it would be appreciated. Thanks.
Old May 13, 2003 | 04:55 AM
v4lu3s's Avatar
RTFM
code 36 is traction control
as far as i know the only way to get rid of it is new ecu though MAYBE chipping it may work.
for code 20 im not sure to start with make sure your ecu plugs are in all teh way.
Old May 13, 2003 | 05:47 AM
junglerunna's Avatar
Default Re: (v4lu3s)
I throw code 36 sometimes also, it seems to only throw when I drive the car hard and spin the tires through first and third, but then just like the egr code I throw it gets resest everytime I turn the car off and start it up again.
Old May 13, 2003 | 09:43 AM
The thing is with the electrical load detector is ive had it for a long time it started when someone stole my cd player and all the loose wires were zapping around in the console. Since then my passenger headlight needed to be regrounded the heat blower only works sometimes and other electrical problems. I think maybe i fryed alot of wires under the dash and i was wondering how I could fix that replace with new ones or just tape up old one..? Thanks.
Old May 13, 2003 | 11:53 AM
hondaeg5's Avatar
Default Re: (jdm94h22acivic)
mine throws code 36 as well. i did a search and found that its a 4 wheel steering code. sure enough i look at my ecu and its a 4w. thankfully i also have a 2w thats getting a spoon program contact prospeed on the board i think he can program it for you
Old May 13, 2003 | 12:41 PM
Jonathan_ED3's Avatar
Default Re: (hondaeg5)
I was told 36 is a ghost code and won't cause a CEL.
Is anybody throwing ONLY 36 and getting a CEL?
I can't tell because I'm throwing 12, and 41 also.
Old May 13, 2003 | 12:47 PM
hondaeg5's Avatar
Default Re: (hot_EH)
maybee.im throwing code 12 as well so i dont know just yet
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH &raquo;</TD></TR><TR><TD CLASS="quote">I was told 36 is a ghost code and won't cause a CEL.
I can't tell because I'm throwing 12, and 41 also. </TD></TR></TABLE>
Old May 13, 2003 | 12:48 PM
I wish I was just throwing that code but unfortunatly I throw that code, and EGR. I would also like to know if anyone is just throwing that code?
Old May 13, 2003 | 07:09 PM
blackedoutcivic's Avatar
i have 12, 14,,36,21, and 41.. no vtec and rev limiter @ 6500... i have lots to work on before the meet sunday!!! anyone have any ideas? which ones are causing the 6500 rev limit?
Old May 13, 2003 | 07:22 PM
poison's Avatar
Default Re: (blackedoutcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackedoutcivic &raquo;</TD></TR><TR><TD CLASS="quote">i have 12, 14,,36,21, and 41.. no vtec and rev limiter @ 6500... i have lots to work on before the meet sunday!!! anyone have any ideas? which ones are causing the 6500 rev limit?</TD></TR></TABLE>
good lord!@ that's a lot of codes you're running lol.
12 - egr (soft code)
14 - iacv (not sure, but this could cause you to go into limp mode)
36 - the launch control people are talking bout. I'm sure a chip would get rid of the problem, not 100% sure though.
21 - vtec solenoid (this could cause you obviously not to go into vtec due to the solenoid probably isn't wired up/break in the wire or bad vtec solenoid
41 - O2 sensor. make sure you have it wired up properly.
Old May 13, 2003 | 07:29 PM
Default Re: (poison)
so "soft" code means it will still allow me to go into vtec right?
[/QUOTE]
Old May 13, 2003 | 07:33 PM
poison's Avatar
yep, soft code means it will not affect the motor with it not hooked up/broken.
things like random misfire, MAP sensor, and such is a hard code that will cause the ECU to go into safe/limp mode so that it will not run any extra functions (vtec and such), run rich, and retard the ignition timing so that the motor will not blow.
Old May 14, 2003 | 04:01 AM
You should def fix those codes, which is why your not running right. Def double check your wiring.
scrambled_EG
Oct 9, 2009 06:42 PM
cheezoto
May 10, 2004 11:43 AM
Jonathan_ED3
Apr 24, 2003 04:45 AM
SolidSpruce
Apr 23, 2003 05:33 PM
Jeef
Dec 9, 2001 06:35 PM
